Amstrad CPC 6128
amstrad_250910_r006.5b.rbf
- Screen C64 wip
Amstrad CPC 6128
amstrad_250915_r006.7b.rbf
- C64 screen with rotate
Amstrad CPC 6128
amstrad_250924_r006.8b.rbf
-C64 palette algo.
-Tested with Winzards Lair
-C64 palette algo.
Amstrad CPC 6128
amstrad_251015_r006.9b.rbf
-C64 palette generated by C64_to_CPC_palette[Eclipse_Java]
-OSD>Screen:C64
-OSD>Screen:C64
Amstrad CPC 6128
amstrad_251016_r006.10b.rbf
-C64 PALETTE mapping fix
Amstrad CPC 6128
amstrad_251017_r006.11.rbf
-palette C64
-rollback OSD "Original", use the setting files to enable original signal.
-scandoubler in text setting instead of OSD
thanks to Robert Kacsich for tests and ideas
-palette C64
