2018.10.15 - Novedades MiSTer
skywalky
Mensaje por skywalky » 17 Oct 2018, 18:48
Pongo todas las novedades que han ocurrido desde el último mensaje de novedades. Lo que ha mejorado mucho es el core de Megadrive / Genesis.
25/09/2018:
TurboGrafx16/PC Engine:
- Option of 64 sprites per line (reduces flickering in some games).
- Fix audio.
- Many fixes and tweaks in video.
26/09/2018:
Genesis:
- Support for Super Street Fighter II mapper.
- Fixes and tweaks in video.
- Fixes and tweaks in audio.
VIC20:
- Add NTSC mode.
- some fixes in C1541.
29/09/2018:
MiSTer:
- Support for composite RBF (boot.rom inside RBF).
to inject the ROM, use this utility:
https://github.com/MiSTer-devel/Injector_MiSTer
Arcade Scramble:
- Separate button for bomb.
03/10/2018:
Genesis:
- PAL mode, JP/US/EU region. (OSD option and F1-F3 keys to choose)
- Support for interlace and double resolution (Sonic 2 split screen)
- Fix the audio frequencies between FM and PSG.
- VDP debug register (Titan Overdrive 2 semi-transparency)
- VDP 128K mode/fast 8bit DMA (Titan Overdrive 2)
- A lot of VDP fixes - many games now look correct.
09/10/2018:
Genesis:
- Implement sprite cache (Titan Overdrive 2)
- Implement Shadow/Highlight (Vectorman, Titan Overdrive 2, Sonic 2 Night mode)
- Adjust scaler parameters for clearer picture.
- Switch to other 68K CPU (some fixes in Jim Power)
- Some fixes in FM and PSG
- Fixes and tweaks in VDP.
- Other fixes and tweaks.
14/10/2018:
Genesis:
- VDP: Fix CODE behavior (Lotus Turbo Challenge, Shinobi III)
- VDP: fix sprites endless loop (Adventures of Mighty Max)
- CPU: fix word swapping (Jim Power)
- Implement TAS bug (Gargoyles)
- FM: fix the timers (music in Thunder Force IV, Double Dragon 2, Titan Overdrive 2)
- Auto region according to file extension (read the ReadMe)
- Gamepad has 3 buttons mode by default
- fix Jim Power graphics.
15/10/2018:
Genesis:
- Use nearest neighbor scaling.
- Update scanline FX to new scaling algo.
- Fix some port unused bits (Turrican)
- VDP: fix window in H40 (Rolling Thunder 2)
