Mensaje por jorsus » 13 Ene 2024, 21:53
menu_240113.rbf
- Shorter hsync/longer back ports at 15kHz
https://github.com/mist-devel/mist-bina ... cores/menu
Mensaje por jorsus » 10 Feb 2024, 20:11
firmware_240210
- Rescan directory, if the OSD size is changed
- Continously check SD card status, reinitialize if removed and reinserted
- USB: fix race condition between SOF IRQ check and reset
- Prevent stuck joystick when opening the OSD
Mensaje por jorsus » 05 Abr 2024, 23:46
firmware_240405
- Enable middle mouse button for minimig core (by retrofun)
- A more efficient method for retrieving the config string added (need mist-modules update in the cores)
- Allow bigger block sizes to be used by cores for VHD I/O
- Full wired XBox360 controller support
Commodore 16
c16_240405.rbf
- Open bus reads from some free ares (fixes Giana Sisters)
- Use PCM sound output from TED instead of PWM for better sound quality
- Update 1541
https://github.com/mist-devel/mist-bina ... /cores/c16
Mensaje por jorsus » 22 Jun 2024, 18:00
Lots of arcade cores from Gehstock's collection & CAPCOM arcades in Jotego's repo:
https://github.com/mist-devel/mist-bina ... res/arcade
Mensaje por jorsus » 11 Jul 2024, 20:04
Arcade - Data East Burger Time Hardware
https://github.com/mist-devel/mist-bina ... 20Hardware
Mensaje por jorsus » 16 Jul 2024, 23:41
Master System
SMS-Nuked_240716.rbf
- New core based on Nuked-SMS-FPGA
https://github.com/mist-devel/mist-bina ... r-mistsidi
Mega Drive
fpgagen_240716.rbf
- Fix IO area decoding (Ballz 3D)
- Auto-detect Virtua Racing cart
https://github.com/mist-devel/mist-bina ... es/fpgagen
Mensaje por jorsus » 19 Jul 2024, 23:17
Mensaje por jorsus » 17 Ago 2024, 22:57
Commodore 64
C64_240814.rbf
- Support Magic Desk 2 format with 2 MiB size
- Don't disable REU when a cart is attached, but no IOF line used
Mensaje por jorsus » 22 Sep 2024, 18:41
firmware_240922
- Minimig: load boot art files from the current directory
- Lot of USB/HID improvements from Eugene Lozovoy (UzixLS). For a list of changes, refer to https://github.com/mist-devel/mist-firmware/pull/118
- Helper function for SNES to auto-detect ROM type. This needs an updated core, too.
Super Nintendo
snes_mist_240922.rbf
- Auto-detect option for ROM files. Needs fw version 240922
https://github.com/mist-devel/mist-bina ... cores/snes
TSConf (advanced ZX Spectrum-compatible platform)
TSConf_240921.rbf
- New core
https://github.com/mist-devel/mist-bina ... res/tsconf
