Mensaje por jorsus » 20 Jun 2023, 08:13
NeoGeo_230620.rbf
- Fixes and some optimizations in the SDRAM controller
- Finished the conversion to synchronous logic. No more latches/generated clocks!
- Use upstream jt12
- Memcard save/load support
- Revisit button assignments
https://github.com/mist-devel/mist-bina ... res/neogeo
Mensaje por jorsus » 09 Jul 2023, 03:05
Mensaje por jorsus » 07 Ago 2023, 02:15
NeoGeo_230806.rbf
- Timer fix in PAL mode
- Some CD related fixes (Double Dragon, Karnov's Revenge)
Mensaje por jorsus » 03 Sep 2023, 14:54
ZXNext
ZXN_230902.rbf
- Update to the latest core (3.02)
https://github.com/mist-devel/mist-bina ... /cores/zxn
Mensaje por jorsus » 03 Dic 2023, 02:22
Super Nintendo
snes_mist_231202.rbf
- Add an NTSC-DeJitter video mode, which breaks 100% cycle accuracy, but works better on some displays
https://github.com/mist-devel/mist-bina ... cores/snes
Mensaje por jorsus » 07 Dic 2023, 01:22
Commodore 64
C64_231205.rbf
- Add the extended Magic Desk cartridge format
- VIC-II: apply color change (background mainly) one pixel earlier (fixes many demos with one-pixel glitches, like Edge of Disgrace or The Space is Broken)
Mensaje por jorsus » 05 Ene 2024, 19:54
Atari 7800
Atari7800_240105.rbf
- New core based on k7800 (c) by Jamie Blanks (Kitrinx)
https://github.com/mist-devel/mist-bina ... /atari7800
Commodore 64
C64_240105.rbf
- Lot of VIC-II accuracy improvements
- Selectable VIC-II variant
Mensaje por jorsus » 06 Ene 2024, 13:58
firmware_231214-intermediate
- An intermediate firmware fixing a firmware upgrade bug with previous versions. Check the readme.md file for important details.
firmware_240105
- Add joystick_disable_swap option
- Fix 'T' menu option if it's above 32 bit
- Add RAMFUNC to timer functions to prevent firmware upgrade locks
- Precheck the firmware before upgrade with the same code as the upgrade, so if it passes, then high chances the upgrade will work, too
- Add ATA commands 21h,31h (by xolod79, for UNEON core)
- Add a BIGOSD feature for 16 line OSDs (by the expense of 2 M9K blocks on the FPGA side), can be requested by a core
- Some more small internal fixes/cleanups
¡MUY IMPORTANTE!
Instalar siempre primero el firmware_231214-intermediate
¡MUY IMPORTANTE!
Si se instala el firmware_240105 sin haber instalado antes el intermediate hay un 99% de probabilidad de brickeo.
¡MUY IMPORTANTE!
Mensaje por jorsus » 11 Ene 2024, 14:26
menu_240111.rbf
- More close to VGA timings (at least in NTSC mode)
- Large OSD (need firmware version at least 240105!)
- Background image changed to 640x312 (reload/resize menu.rom, if using it)
https://github.com/mist-devel/mist-bina ... cores/menu
