Commodore 64
c64_200925.rbf
-Paged OSD
-CTRL-F11 as soft reset
-Some internal updates
c64_200925.rbf
-Paged OSD
zxspectrum_201002.rbf
- Use the original PSG from MikeJ
- General Sound register access fixes (e.g. Alienate demo)
Amiga RTG
minimig_mist_rtg_201006.rbf
- Significant performance increase of the Fast RAM cache
- Master clock is switched between PAL (28.375 MHz) and NTSC (28.6363 MHz)
- The old video filters for chipset video are re-enabled
https://github.com/mist-devel/mist-bina ... inimig-aga
firmware_201011
- Fix the clock_freq setting
- Add a mouse_speed setting to scale the mouse movement by percentage
minimig_mist_rtg_201017.rbf
- Fix the RAM selector (applied only at reset)
- Fix Chip RAM mirrors (Kickstart 1.2 works again)
- Slight Fast RAM cache improvement
- TG68K update - all instructions pass the tester
amstrad_201120_r005.8.16.8.5c
- reset on simple_gatearray_interrupt
- => moustache stress test stabilized
Atari 2600
a2600_201121
- Fix 2k cart mirroring
- Fix 8k cart default bank
- TIA: fix center signal (Bird and Beans)
https://github.com/mist-devel/mist-bina ... ores/a2600
a2600_201121
Firmware_201122
- IDE handling cleanup
- Send Ethernet config periodically to the FPGA
- Add 0b95:772B noname USB Ethernet adapter
- Composite blending setting for MiST2
Amiga RTG
minimig_mist_rtg_201122.rbf
- Fix border blank (by AMR)
- Add +4MB Fast RAM (+2MB if Slow RAM is enabled) (by AMR)
- Enable the cache for Turbo Chip RAM
- 32 bit access to normal Chip RAM in AGA
- Slow RAM is always Turbo in AGA
- Gayle IDE irq flag fix
- Swap left&right audio channels
Atari ST
MiSTery-201122.rbf
- Add Ethernec support
- Gauntlet II interface fix
- Add composite-like blending
- Connect 2nd fire button on joyport0
https://github.com/mist-devel/mist-bina ... es/mistery
Atari ST
MiSTery-201122.rbf
Atari ST
MiSTery-201126.rbf
- Fix some reset issues (shifter desync, extra RAM)
- Simulate up and down keypresses with the mouse wheel
Firmware_201126
- Fix unnecessary RDB generation for some HDF images
MiSTery-201126.rbf
Firmware_201126
