2018.11.29 - Novedades MiSTer
skywalky
Mensaje por skywalky » 30 Nov 2018, 15:21
Pues hay muchas novedades desde el último hilo, nuevos cores, el de Altair 8800 y de Super Nintendo, y actualizaciones en muchos cores destacando el soporte de Game Gear en el core de Master System.
29/11/2018:
New core: SNES
- Update the MiSTer binary!
MiSTer:
- Support for SNES.
- Fix KBD toggle key (auto-fire on/off for keyboard).
28/11/2018:
ColecoVision:
- Updates from MiST version: Megacart, YM2149
- This core requires SDRAM board from now.
- Support for scaler coefficients
26/11/2018:
Genesis:
- Minor updates in JT12.
- Minor update in PSG.
- Implement window bug (fixes Barkley Shut Up and Jam)
- Support for backup RAM save (only for SRAM games!)
- Supports for up to 14.5MB mapper-less ROMs (UMKT, UMKT+Tracks).
24/11/2018:
Genesis:
- new JT12 from José Tejada Gómez (Titan 2 music is perfect now)
- Workaround for Joe & Mac
- Fix Joystick port (Decap Attack)
- Some other tweaks.
21/11/2018:
MiSTer:
- Automatic save file creation (on supported cores)
18/11/2018:
Genesis:
- Cycle accurate CPU from ijor
- Tweaks for new CPU.
- More workarounds for games using EEPROM, SRAM, J-CART
NES:
- Support for Famicom Disk System (You need to load original FDS BIOS before use FDS dumps!)
- More palettes
- Support for scaler coefficients (put them into Filters folder)
- Use T65 as a most complete 6502 CPU
- Many fixes.
SMS:
- Game Gear support (experimental)
Gameboy:
- A lot of fixes!
TurboGrafx16:
15/11/2018:
MiSTer:
- Support for scaler coefficient file loading at runtime (files should be put into /Filters folder).
- Improved analog stick to dpad conversion (as proposed by olin)
- Support for USB-MIDI
Genesis:
- Support for scaler coefficient file loading at runtime (Update MiSTer binary!).
- Adjust VDP timings (Toy Story)
- Workaround for some games using EEPROM/SRAM (NBA Jam TE, College Slam, Evander Holyfield, NFL Quarterback Club, Frank Thomas Big Hurt Baseball)
- Adjust FM/PSG volumes.
- Fix Space Harrier II sound.
P.S.: This release still uses old CPU!
14/11/2018:
New core: Altair 8800
https://github.com/MiSTer-devel/Altair8800_Mister
