2018.11.11 - Novedades MiSTer
Publicado: 14 Nov 2018, 15:57
Nuevo mensaje sobre las novedades en los cores para MiSTer desde la última actualización. Siguen los avances para Megadrive/Genesis, actualización del core de Sega Master System con guardado de partidas, soporte MIDI para los cores de 486 y Amiga y alguna cosita más:
11/11/2018:
Genesis:
- Support on-cart SRAM (Buck Rogers, Primetime NFL, some other games)
- Fix shadow/highlight (Toughman Contest)
- Fix HINT in the last line (Sonic 1 garbage, Turbo Outrun)
- Fix FM reset (Turbo outrun)
- Update JT12(FM) to latest version (should fix the sound in many games)
- Fixes in VDP (Viewpoint).
- Option for fast VRAM access (fixes Clue garbage in NTSC mode)
08/11/2018:
Linux:
- Support for MIDI (Minimig, ao486)
05/11/2018:
Genesis:
- Fix Shadow/Highlight (Toughman Contest).
- 2-stage sprite render for precise timings (Titan 1/2).
- SRAM support (Buck Rogers and other games)
- Relax VDP external slots in inactive area (glitches in Clue, Sonic 1)
- Rework Z80 BUS.
- Rework 68K BUS.
- Clear VRAM/RAM on ROM loading (fix garbage in some ROMs)
- Audio tweaks for HDMI (possible audio absence fix on some TVs).
31/10/2018:
MiSTer:
- Joystick: system-wide definition for menu navigation.
Joystick buttons defined in Menu core are now used for menu navigation for all cores.
30/10/2018:
Genesis:
- Fix Z80 control (broken sound in SSF2,Xenon2)
- Fix interrupts (broken backgrounds in SSF2)
- Support for invalid backgrounds (Super Skidmarks)
- Adjust FIFO throttle (dots in Outrunners USA)
- Remove unused TMSS replacement ROM.
- Adjust RAM/ROM access.
29/10/2018:
Genesis:
- Many fixes and tweaks in VDP.
21/10/2018:
SMS:
- Save support
- Many fixes from GreyRogue
- Some fixes and updates from me.
- Support for scaler coefficients loading
19/10/2018:
MiSTer:
- Load <core>/coeff.txt to scaler on supported cores.
- ini option for vertical integer scaling.
- Merge SharpMZ support code.
Genesis:
- Update unused bits values (NBA Jam)
- Fix scanlines FX
- VDP fixes (Bram Stokers Dracula, Fatal Rewind)
- FM: implement LFO. Increase the volume.
- Support for external coefficients for scaler (update the MiSTer!).
11/11/2018:
Genesis:
08/11/2018:
Linux:
05/11/2018:
Genesis:
- Rework Z80 BUS.
- Rework 68K BUS.
31/10/2018:
MiSTer:
30/10/2018:
Genesis:
29/10/2018:
Genesis:
21/10/2018:
SMS:
- Save support
19/10/2018:
MiSTer:
Genesis:
- Fix scanlines FX
