Página 10 de 20
Publicado: 08 Mar 2021, 12:23
por jorsus
Publicado: 11 Mar 2021, 23:40
por jorsus
Macintosh Plus and Macintosh 512Ke
plusToo_210311.rbf
- FX68K/TG68K selectable CPUs
- RTC/PRAM support (can boot OS 7.5)
- Two harddisks support without (reasonable) size limt
- Use the cycle-exact VIA from Gideon
https://github.com/mist-devel/mist-bina ... s/plus_too
Publicado: 17 Mar 2021, 20:32
por jorsus
ZX Spectrum Next
ZXN_210317.rbf
- Enable 28 MHz mode
- Some internal fixes
https://github.com/mist-devel/mist-bina ... /cores/zxn
Publicado: 23 Mar 2021, 00:24
por jorsus
ZX Spectrum Next
ZXN_210322.rbf
- Stabilty improvements
- Increase the performance of the SD Card
- Add tzxplayer
Publicado: 27 Mar 2021, 02:46
por jorsus
ZX Spectrum Next
ZXN_210327.rbf
- Fix an off-by-one error of the TZX playing
- Port the CPU fixes from the pure ZX core
- Add Sinclair and Cursor joysticks
Publicado: 29 Mar 2021, 19:32
por jorsus
plusToo_210329.rbf
- Implement the video back buffer
- Keyboard/Keypad fix
- 16 MHz was not enabled for TG68K, fixed
Publicado: 31 Mar 2021, 00:30
por jorsus
Publicado: 31 Mar 2021, 21:56
por jorsus
Commodore 16
c16_210331.rbf
- TED: revert a wrong change (thanks to Istvan Hegedus).
- Update T65/1541
- Allow unmountig of disks from the OSD (requires firmware 210330)
https://github.com/mist-devel/mist-bina ... /cores/c16
Commodore 64
C64_210331.rbf
- Adjust motor momentum timing (fixes some loaders)
Texas Instruments TI-99/4A
Ti994a_210331.rbf
- SDRAM controller update
https://github.com/mist-devel/mist-bina ... res/ti994a
ZX Spectrum
zxspectrum_210331.rbf
- TZXplayer update
- Get rid of GLUK ROM
- Add DivMMC RAM/ROM extension (hint: ESXDOS)
- T80 interrupt acknowledge fixes (not really affecting the Speccy)
Publicado: 02 Abr 2021, 01:26
por jorsus
atari800_210402.rbf
- Add a joystick swap option
https://github.com/mist-devel/mist-bina ... s/atari800
Publicado: 03 Abr 2021, 00:03
por jorsus
BBC Micro Model B/Master
bbc_210402.rbf
- Use 48 MHz main clock to be synchronous with both the Teletext and ULA
- FDC update (fix write corruption)
- RTC support
- CMOS RAM save/load support
https://github.com/mist-devel/mist-bina ... /cores/bbc
