jorsus
ULA
Mensaje por jorsus » 29 Jun 2022, 20:46
firmware_220629
- Close the OSD after NVRAM save (#93)
- Increase max. RBF filename to 32 in ARC files
- Enable PGUP/PGDN keys in the menus
- Save 32/64 bit values in hexa format in CFG files
- Correct Delete key in PS2 Set 1 (affects Next186)
- Add Retro Games THEGAMEPAD USB IDs (retrofun)
- Add keypad Enter as select key for menu items (retrofun)
- Fix the 'V' string in the helptext, too (#88)
- Reconnect the USB device when a new core was loaded
jorsus
ULA
Mensaje por jorsus » 02 Jul 2022, 12:44
firmware_220701
- Add selective ack for SD IO, for easier support of multiple disk images
apple2e_220701.rbf
- Fix disk writes when dirty track buffer left in memory before disk change
- Add support for 2 disks. Need at least firmware version 220701!
https://github.com/mist-devel/mist-bina ... s/appleIIe
jorsus
ULA
Mensaje por jorsus » 07 Jul 2022, 15:06
Megadrive
fpgagen_220706.rbf
- Update jt12/jt89
- Multitap support
- Fix 68K RAM writes from Z80 (fixes Mamono Hunter Yohko)
https://github.com/mist-devel/mist-bina ... es/fpgagen
jorsus
ULA
Mensaje por jorsus » 23 Jul 2022, 03:14
NUEVO CORE --- Commode PET
pet2001_220722.rbf
- New core, ported from https://github.com/skibo/Pet2001_Nexys3 by way of the MiSTer port.
- Uses SDRAM for ROM and Tape.
https://github.com/mist-devel/mist-bina ... ster/cores
jorsus
ULA
Mensaje por jorsus » 05 Ago 2022, 22:48
firmware_220805
- Resurrect USB storage driver (host) - an USB drive can be used instead of the SD Card
- Fix saving of Minimig's dither settings
- Fix a possible disk corruption during Minimig floppy writes (Heimdall 2 save disk)
- Add joystick_dead_range setting (useful for paddles)
- Other internal fixes and changes for timers and USB
jorsus
ULA
Mensaje por jorsus » 14 Ago 2022, 14:03
Amstrad
- Merge of z80pa from MiSTer Amstrad
jorsus
ULA
Mensaje por jorsus » 16 Ago 2022, 14:01
Amstrad CPC
amstrad_220816_r005.8.16.9.6c1.rbf
- merge last T80
- undo two bad T80 timing updates, cause BATMAN is slow in some part with them. BATMAN CRTC1 ok
- PHX is ok until fish, thanking are not displayed but sound is here, demo run on loop ok.
jorsus
ULA
Mensaje por jorsus » 22 Ago 2022, 00:31
firmware_220821
- Switch boot from SD/USB with user button (by retrofun)
- ATAPI CDROM support in the IDE module
PC AT
Next186_220821.rbf
- Some VGA fixes
- IDE support (Primary slave/Secondary master and slave)
https://github.com/mist-devel/mist-bina ... es/next186
Amiga AGA-RTG
minimig_mist_rtg_220821.rbf
- Fixed bitplane offset bug which broke blitterscreens with sprite masks (by AMR)
- Implemented ToD clock bug, fixes music for Torvak the Warrior (by AMR)
- Tweaked bitplane shifting, fixes offset logo in 3le-Passengers (by AMR)
https://github.com/mist-devel/mist-bina ... inimig-aga
jorsus
ULA
Mensaje por jorsus » 26 Ago 2022, 20:31
firmware_220826
- Many IDE/ATAPI related fixes
PC AT
Next186_220826.rbf
- IDE/ATAPI CDROM related fixes
Amstrad_alt CPC 6128
Amstrad_220826.rbf
- FDC & CRTC related fixes
- Symbiface II support with IDE and RTC
https://github.com/mist-devel/mist-bina ... mstrad_alt
jorsus
ULA
Mensaje por jorsus » 07 Sep 2022, 01:03
firmware_220906
- Some IDE/ATAPI related fixes
- Support playback of CD Audio
- Load optional <corename>.R0[1-6] files at core boot
minimig_mist_rtg_220906.rbf
- CD audio playback
