Mensaje por jorsus » 19 Mar 2022, 21:39
PC AT
Next186_220319.rbf
- Implement programmable CRTC timings (Battle Isle 2, Flashback using it for custom video modes)
- Fix VGA address wraparound (Raiden, Alien Breed, etc.)
https://github.com/mist-devel/mist-bina ... es/next186
Mensaje por jorsus » 29 Mar 2022, 19:55
Atari ST
MiSTery-220329.rbf
- Internal Cubase dongle support (update the firmware, too!)
https://github.com/mist-devel/mist-bina ... es/mistery
firmware_220329
- Cubase dongle support in the Atari ST menu
Mensaje por jorsus » 02 Abr 2022, 05:19
Atari ST
MiSTery-220401.rbf
- Support the Cubase 2 dongle as well
Mensaje por jorsus » 17 Abr 2022, 04:39
PC AT
Next186_220416.rbf
- More VGA improvements
- Flush the instruction queue on reg->mem writes (fixes Army Moves and other Dinamic games)
- Preliminary Tandy sound and video support
Mensaje por jorsus » 20 Abr 2022, 20:17
Sega Megadrive
fpgagen_220420.rbf
- Update JT12
- Return FM status register as in Model 1 (fixes Hellfire)
- Clear RAM after ROM loading (fixes Handy Harvy)
- Merge robinsonb5's DeMISTify branch with some SDRAM controller updates
https://github.com/mist-devel/mist-bina ... es/fpgagen
Mensaje por jorsus » 05 May 2022, 18:01
ZX Spectrum 128K
zxspectrum_220505.rbf
- Add CRC_ON_OFF command to SD card driver (for Wildplayer DivMMC)
- Fix unreadable menu when scandoubled disabled
- Add Covox at #FB port and SounDrive at #0F,#1F,#4F,#5F ports
- Increase brightness for colors without BRIGHTNESS bit Thanks to Eugene Lozovoy (UzixLS) for these patches!
Mensaje por jorsus » 08 May 2022, 16:16
PC AT
Next186_220508.rbf
- Implement 40 char text modes
- Expand hcounter to 11 bit (fixes Simpsons arcade)
- Implement the preset row scan CRTC register
- Option to hide Adlib (for games like Dimo's Quest)
- Add /32 speed option (for near XT speed)
- Output active negative syncs
- Increased BIOS size to 16K (The core won't work with the old BIOS! Also update the FONT.EXE from font-BIOS16k.zip)
Mensaje por jorsus » 30 May 2022, 19:52
Commodore 64
C64_220530.rbf
- 1541 fix for Krill's loader
- Prophet64 cartridge support with second SID
- 6850 ACIA based MIDI interfaces
- UP9600 wiring of the user port
- G64 support for 1541 (loads some protected disks)
Mensaje por jorsus » 07 Jun 2022, 23:17
Apple //e
apple2e_220605.rbf
- Generic updates in mist-modules/mockingboard/CPU/etc.
- Disk write support (tested in DOS 3.3 only)
- Apple keys are mapped to left/right ALT
https://github.com/mist-devel/mist-bina ... s/appleIIe
Mattel Intellivision
intv_20220607.rbf
https://github.com/mist-devel/mist-bina ... ellivision
Mensaje por jorsus » 18 Jun 2022, 04:42
atari800_220617.rbf
- Support for ATX and XFD disk images
https://github.com/mist-devel/mist-bina ... s/atari800
