Mensaje por jorsus » 24 Ago 2021, 22:13
Nintendo NES
nes_210824.rbf
- Fix backup RAM reading/writing from/to the SD card
https://github.com/mist-devel/mist-bina ... /cores/nes
ZX Spectrum 128k
zxspectrum_210824.rbf
- Add Issue2/Issue3 selector
- Option to disable snowing (unrainer)
- Sinclair II joystick and Kempston mouse fix
Mensaje por jorsus » 21 Nov 2021, 20:47
firmware_211121
- Use hardware-controlled NPCS lines for SPI
- Add mass-storage device support (MiST as USB drive - need mass_storage=1 in mist.ini)
- Add Xbox360 controller support (digital parts only, tested with a Retroflag classic USB gamepad)
Mensaje por jorsus » 25 Nov 2021, 21:23
Mistica MSX1 Core
- keyb fix by rampa
https://github.com/ManuFerHi/SiDi-FPGA/ ... puter/MSX1
Mensaje por jorsus » 27 Nov 2021, 10:09
vic20_211127.rbf
- VIC-I color-pixel data alignment fix (thanks, AMR!)
- Audio filter simplifications / improvements by AMR
- 1541 update from C64/C16, add disk unmounting to OSD
https://github.com/mist-devel/mist-bina ... ores/vic20
colecovision_211126.rbf
- Increase keyboard FIFO size to avoid overflow
- Change SDRAM drive strength to 8mA
- Update the CPU and other components
https://github.com/mist-devel/mist-bina ... lecovision
Ti994a_211126.rbf
- Use higher SDRAM clock
https://github.com/mist-devel/mist-bina ... res/ti994a
Mensaje por jorsus » 12 Dic 2021, 01:33
Amstrad_211211.rbf
- Some FDC updates
- Fix some CRTC behavior (especially CRTC0 ones)
- Allow umounting disk images from the OSD
https://github.com/mist-devel/mist-bina ... mstrad_alt
Mensaje por jorsus » 20 Dic 2021, 23:37
Commodore 64
C64_211220.rbf
- CIA Timer fixes
- VIC-II: latch xscroll one pixel later (Happy 2021 demo)
- Keyboard numpad symbol support
- REU up to 16 MB with original timings and bus arbitration
Mensaje por jorsus » 24 Dic 2021, 16:29
Commodore 64
C64_211224.rbf
- Merry "Treu Love" Christmas!
Mensaje por jorsus » 12 Ene 2022, 18:00
firmware_220112
- Fix some issues regarding to the new menu engine (thanks retrofun to fix Minimig profile loading).
- Query the device descriptor only once for USB devices. This might prevent (un)expected mode switch.
- Convert [corename].CFG files to INI format. The old file will still load, but Save settings will write in INI.
- Add a MISTCFG.INI file for global settings, writeable for the firmware itself.
- Add an interactive joystick map configuration to the Input Test OSD page. Read the scrolling helptext for usage.
- Send a default date to the cores if no USB-RTC found.
Mensaje por jorsus » 13 Ene 2022, 21:01
firmware_220113
- Fixes regarding to joystick_remap parsing
Mensaje por jorsus » 14 Ene 2022, 22:20
vic20_220114.rbf
- Mega-Cart support (Mega-Thanks to AMR!)
