jorsus
ULA
Mensaje por jorsus » 24 Abr 2021, 20:15
Sega Master System and Game Gear
sms_210424.rbf
- Boost PSG and FM volume, and replace the DAC (by robinsonb5)
- Adjust VDP collision flag (for Donkey homebrew)
https://github.com/mist-devel/mist-bina ... /cores/sms
ZX Spectrum 128K
zxspectrum_210424.rbf
- Adjust Pentagon interrupt and border timings
- Don't mix NMI key with reset (F10 - NMI, F11 - Reset)
https://github.com/mist-devel/mist-bina ... s/spectrum
jorsus
ULA
Mensaje por jorsus » 26 May 2021, 03:22
Firmware_210525 ---- Major update! ----
- AMIGA_MOD_KEYS option by retrofun
- Better handling of non-bootp capable keyboards (Arduino)
- FAT driver replaced with FatFs (http://elm-chan.org/fsw/ff/00index_e.html)
- exFAT support, >4GiB file size support (on exFAT formatted cards)
- Long name support in Minimig, Atari ST and Archie config files (up to 64 chars)
- PCE-CD support
Note: Minimig, Atari ST and Archie config files have to be reset and resaved.
PC Engine
tgfx16_210525.rbf
- CD support (need recent firmware)
https://github.com/mist-devel/mist-bina ... s/pcengine
jorsus
ULA
Mensaje por jorsus » 30 May 2021, 20:37
firmware_210530
- PCE-CD: fix a BCD->binary conversion in PCECD_COMM_GETDIRINFO
- PCE-CD: slow down sector reads for HuVideo
- Enhance max. kickstart file name to 79 (sorry, need to reset and resave Minimig configs again)
- Support LBA28 mode for IDE (>8GiB image support for Minimig, up to 137 GiB on exFAT)
- Display a warning if HDF indexing fails (and continue with reduced performance)
- Fix one char extension selection (affects ZX81, TI99/4A)
PC Engine
tgfx16_210529.rbf
- Fix several reported bugs and glitches (need a firmware update for all fixes - will released soon)
jorsus
ULA
Mensaje por jorsus » 17 Jun 2021, 01:15
Megadrive
fpgagen_210616.rbf
- Try again to simulate RAM refresh delays
- Fix writing save RAM to SD Card
https://github.com/mist-devel/mist-bina ... es/fpgagen
jorsus
ULA
Mensaje por jorsus » 18 Jun 2021, 14:44
firmware_210618
- Compiled in thumb mode
- Fix a nasty long-standing buffer overflow in Minimig menu code
- 4 IDE drive support on Minimig (need IDEFix/ATAPIMagic)
- INI config format for Minimig (last time it has to be recreated)
- PCECD fix for playing the last track
- VHD= in ARC file
- And some other minor updates
Super Nintendo
snes_mist_210618.rbf
- Fix SAV file writing
- Updates from upstream
https://github.com/mist-devel/mist-bina ... cores/snes
jorsus
ULA
Mensaje por jorsus » 19 Jun 2021, 02:41
Amiga
minimig_mist_rtg_210618.rbf
- Add support for secondary IDE channel (need IDEFix/ATAPIMagic)
- 64 MB RAM support
- Tentative CIA fix for OS3.1.4 time gain problem
- RTG now supports 16 bit as well as 15 bit
https://github.com/mist-devel/mist-bina ... inimig-aga
jorsus
ULA
Mensaje por jorsus » 21 Jun 2021, 20:07
Macintosh Plus
plusToo_210620.rbf
- Support Macintosh SE mode (automatically switched if a 256KB SE ROM is used)
- Support 4 SCSI drives (need at least firmware 210618!)
- Greatly increased SCSI performance
https://github.com/mist-devel/mist-bina ... s/plus_too
jorsus
ULA
Mensaje por jorsus » 23 Jun 2021, 19:14
Macintosh Plus
plusToo_210622.rbf
- Fix SCSI bugs: data corruption, 3rd and 4th drives, GET CAPACITY command
- Add fake VERIFY commands to SCSI - some formatters are using it
jorsus
ULA
Mensaje por jorsus » 25 Jun 2021, 22:49
Macintosh Plus
plusToo_210625.rbf
- TG68K update: MOVEP fix for SCSI (works now in SE mode)
- Speed up ADB transmission for TG68K/16MHz mode
jorsus
ULA
Mensaje por jorsus » 27 Jun 2021, 19:50
Sinclair QL
ql_210627.rbf
- Second microdrive support added. Games that require MDV2_ support, like "QL Pawn", are now supported.
- Selectable ROM added
- Games/Software moved to "QL Software Collection" on archive.org
https://github.com/mist-devel/mist-bina ... r/cores/ql
