Texas Instruments TI-99/4A
Ti994a_201201.rbf
- Add a PHP1240-compatible single-density disk controller
https://github.com/mist-devel/mist-bina ... res/ti994a
Ti994a_201201.rbf
Amstrad CPC 6128
Amstrad_201212.rbf
- Change VSYNC triggering in the CRTC (Onescreen Colonies #0)
- Add Alt-F11 as reset
https://github.com/mist-devel/mist-bina ... mstrad_alt
ZX Spectrum 128K
zxspectrum_201212.rbf
- Fix Kempston mouse
- Z80 (both 128K and 48K) and SNA (48K only) snapshot loading
- More joystick options
- Tape input polarity and EAR output feedback fix
Amstrad_201212.rbf
ZX Spectrum 128K
PCEngine/TurboGrafx16
tgfx16_201230.rbf
-New TurboGrafx16 core based on srg320's code
https://github.com/mist-devel/mist-bina ... s/pcengine
tgfx16_201230.rbf
MegaDrive
fpgagen_210108.rbf
- VDP T80 interrupt length fix (Metal Blast 2277)
- VDP Vcounter reload with NTSC/V30 mode fix (SOR2 Simpsons hack)
- Allow using the save RAM in Sonic Delta 40Mbit ROM hack
- CRAM dots option
- Lightgun support (single Menacer or single/dual Justifier) via mice
https://github.com/mist-devel/mist-bina ... es/fpgagen
fpgagen_210108.rbf
- CRAM dots option
Amstrad_201223.rbf
- CDT player fixes
- Add a progressbar for CDT playback
- CDT player fixes
MIST/Mistica Firmware
firmware_210130.upg
Atari 800XL
atari800_210130.rbf
-New version with standard video settings and OSD
https://github.com/mist-devel/mist-bina ... s/atari800
AtariST
MiSTery-210130.rbf
-Blitter force dest read fix regarding to endmasks
-Add selectable 68020 CPU (TG68K)
https://github.com/mist-devel/mist-bina ... es/mistery
firmware_210130.upg
Atari 800XL
atari800_210130.rbf
AtariST
MiSTery-210130.rbf
Commodore VIC 20
vic20_210205.rbf
- Same VIA is used in the machine and 1541
- Lot of VIC-I fixes (RL, IMPO3 demos are much better)
https://github.com/mist-devel/mist-bina ... ores/vic20
ZX80/ZX81 core
zx8x_20190414.rbf
- Update CPU
- Route vsync to audio via a high pass filter - for tape save audio (and sound demos).
https://github.com/mist-devel/mist-bina ... cores/zx01
vic20_210205.rbf
ZX80/ZX81 core
zx8x_20190414.rbf
- Update CPU
Super Nintendo Mistica
- Cycle accurate SNES replica.
- Supports LoROM, HiROM, ExHiROM.
- Supports additional chips: DSP-1/2/3/4/ST010, S-RTC, OBC-1
- Save/Load Backup RAM.
- Video support: VGA, RGB, YPbPr.
The snes_mistica rbf files have timing changes for more stability on the Mistica
https://github.com/mist-devel/mist-bina ... cores/snes
snes_mist_210226.rbf
- Updates from upstream
- Add Justifier lightgun option
zxspectrum_210226.rbf
- Fix F10 and F11 shortcut keys
- TZXPlayer update from Amstad CPC
- TZXPlayer improvement: different length of header and data tones
nes_210302.rbf
- APU rewrite by Kitrinx
- Fixes for mappers 18,30,32,88,97,38,165
- Backup RAM support
https://github.com/mist-devel/mist-bina ... /cores/nes
C64_210302.rbf
- Simulate tape momentum in the TAP player
- Add a progressbar for tape playing
C64_210302.rbf
