jorsus
Mensaje por jorsus » 03 Oct 2020, 15:35
Commodore 64
c64_200925.rbf
-Paged OSD
-CTRL-F11 as soft reset
-Some internal updates
jorsus
Mensaje por jorsus » 03 Oct 2020, 15:36
zxspectrum_201002.rbf
- Use the original PSG from MikeJ
- General Sound register access fixes (e.g. Alienate demo)
jorsus
Mensaje por jorsus » 07 Oct 2020, 00:17
Amiga RTG
minimig_mist_rtg_201006.rbf
- Significant performance increase of the Fast RAM cache
- Master clock is switched between PAL (28.375 MHz) and NTSC (28.6363 MHz)
- The old video filters for chipset video are re-enabled
https://github.com/mist-devel/mist-bina ... inimig-aga
jorsus
Mensaje por jorsus » 11 Oct 2020, 15:30
firmware_201011
- Fix the clock_freq setting
- Add a mouse_speed setting to scale the mouse movement by percentage
jorsus
Mensaje por jorsus » 17 Oct 2020, 23:22
minimig_mist_rtg_201017.rbf
- Fix the RAM selector (applied only at reset)
- Fix Chip RAM mirrors (Kickstart 1.2 works again)
- Slight Fast RAM cache improvement
- TG68K update - all instructions pass the tester
